acceleration limit for IRBT2005
Options
Good evening,
Can I get some help regarding limiting acceleration for IRBT2005 track ? I know for the robot it is AccSet, but it's not working for track,
Thank you
Thank you
In the MOC configuration for the unit, you could try wc_acc.Lee Justice0
Im not having any wc_acc param.As you can see in the capture below
But I think that maybe the param. between rectangle can make a change ?
I cannot read the text, it is too small for me. I suggest that you read the system parameter manual, under the motion topic, Acceleration data type.Lee Justice0
- 5.4K RobotStudio
- 384 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 406 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 736 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
