[OpcUaClient] Doesn't work with Anybus
DenisFR
We test the OpcUaClient to connect a simulated B&R PLC with a virtual controller.
We see that using "841-1 EtherNet/IP Scanner/Adapter" works fine but using "840-1 EtherNet/IP Anybus Adapter" failed with error:
Bad result writing OPC UA data for node ::AsGlobalPV:RobotOutputs (status: 2155085824).
Device received the good data (input) but can't send them to PLC (output).
Does anybody have this error too?
UP
UP
UP
Denis, please reach out to your local ABB with this issue and report it as a potential bug.
Thanks.
Post update for RS 2023.4.1:Test creating an EthernetIP_Anybus with 128I/128O:And an EthernetIP with 128I/128O too:I've start OPC UA Client Configuration and add Controller Device I/O mapping:With EthernetIP it works fine:☑️2024 - RobotStudio® User Group0
Still here in 2024.1
Still presents in 2024.2.1
Still present in 2025.2☑️2024 - RobotStudio® User Group0
Hi Denis,
Did you report this via Local ABB?
Hello,Yes☑️2024 - RobotStudio® User Group0
@DenisFR can you PM me the case number/work item number please?
Still present in 2025.3☑️2024 - RobotStudio® User Group0
- 84 OmniCore
- 37 AppStudio
