DeviceNet with two Robot Controller as Master
Options
orka375
I'm new to DN with two masters.
We have a robot-setup with two robot controller (2x IRC5) in the same Devicenet. Additionnally a Conveyortracker (DSQ377A)
And I would like that, both controller can communicate with the same QTrack
We have the Problem, that when you start the system, the start of the DeviceNet fails.
On one controller I get the error code: 71310: That the QTrack Unit is already occupied by an other master.
And on the other controller I get the code: 71058: That the connection to the QTrack Unit was lost.
Configuration:
IRC5-Compact: DN address: 1
QTrack1 - DeviceNet1 - d377A - address: 13
DNSlave - DeviceNet1 - DN_INTERNAL_SLAVE
IRC5: DN address: 2
Do I need to change the configuration?
Configuration:
IRC5: DN address: 2
- 5.4K RobotStudio
- 381 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 406 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 280 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 737 RAPID Programming
- 16 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
