bind tcp to an external rotary axis
I'm programming an ABB IRB6700 robot with 7 axes that needs to pour aluminum into a shell.
Axis 7 of the robot is a rotary type and moves that cup( And it's on the robot).
I am looking for an instruction or functions that allow me to make a movement similar to the RelTool. That way I could place my tool in the tip of the cup and move it as it rotates.
I don't know if I have explained myself correctly....
Hi...If I understand, you could use a stationary tool so you could use RelTool with this tool.Take a look at this tip:
https://forums.robotstudio.com/discussion/311/stationary-tool-wobj-setting
Good work.0
