Robot not reorienting around tcp, works in robotstudio but not on real robot.
Hello, so I have a problem.
Have been trying to figure this on my own but now i think it s time to ask for help.
So I´ve created a tool in solidworks and made a .STEP file to get it into Robotstudio.
Everything has been working fine, up until I downloaded it into the real controller for verification.
Then i noticed that the robot is not rotating correctly around the TCP.
Video:https://imgur.com/a/KaEbRiv
Do you have any ideas?
I´ve verified that the tool is mounted correctly on the robot, that the revolution counters are updated and also that the X,Y,Z coordinates are correct.
Updated to RW 6.15.06.00.
The robot has been in our development site since 2017 with no service that i know of(If this is information that could be helpful)
Thanks in advance!
Best regards, ENO
Best Answer
  • lemster68
    lemster68 ✭✭✭
    Answer ✓
    There should be a sticker on the robot arm which has the robot type, serial numbers and those numbers for calibration offsets.  These numbers should match what you see in the pendant.  AT this point, please also check that the robot serial numbers matches the sticker on the controller.
    Lee Justice
  • lemster68
    lemster68 ✭✭✭
    Did you verify the calibration offsets also?
    Teach the TCP and see if you can get a good result.
    Lee Justice
    Have a look here: https://imgur.com/a/vfNqVuo
    Max error 5.12mm.
    We do not have a tcp pen, we are using the welding wire from the nozzle.
    The robot is an IRB4600-40/2.55C, as I´ve understood this is not the most accurate robot but i feel like we should get a better value than that anyway.
  • lemster68
    lemster68 ✭✭✭
    Are you telling me that is the result of teaching a tcp?  And what about the calibration offsets?
    Lee Justice
    Sorry for a noob question, but how do I verify this?
    Please have a look on this, is this what you are searching?
    https://imgur.com/a/uiMMS3O
    They no not match, so i guess this might be my problem.
  • DenisFR
    DenisFR ✭✭✭
    You can check your motor turn with MoveAbsJ [0,0,0,0,0,0],...
