Changing Instructions process template
sturner
Is it possible to change a programmed move instructions template.
When modifying an Instruction, like MoveL in the stations path, to a different process template like Plasma_LOn it looses the target and cannot get it back.
If I manually Teach a move Instruction with the PlasmaLOn, the process Instruction works fine but changing its template back to MoveL looses the target again.
Any suggestions would be appreciated?
Thanks in advance
Because of a bug
is it not possible to change process in a path, in RS 5.10.
So you must select the correct process template before you create the motion instruction.
We are working on a solution for this for the next release.
ABB Robotics0 -
Many thanks0
- 399 UpFeed
- 20 Tutorials
- 14 RobotApps
- 301 PowerPacs
- 406 RobotStudio S4
- 2.8K Robot Controller
- 337 IRC5
- 67 OmniCore
- 831 RAPID Programming
- 14 AppStudio
- 107 Collaborative Robots
