Changing Instructions process template
sturner
Is it possible to change a programmed move instructions template.
When modifying an Instruction, like MoveL in the stations path, to a different process template like Plasma_LOn it looses the target and cannot get it back.
If I manually Teach a move Instruction with the PlasmaLOn, the process Instruction works fine but changing its template back to MoveL looses the target again.
Any suggestions would be appreciated?
Thanks in advance
Because of a bug is it not possible to change process in a path, in RS 5.10.
So you must select the correct process template before you create the motion instruction.
We are working on a solution for this for the next release.
Many thanks0
- 5.4K RobotStudio
- 384 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 736 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
