RobotStudio 5.09
PaTa
I have RobotStudio 5.09. Now I want to simulate the program from S4C M98A robot.
How can I do that and what I have to change from parameters???
S4C is not supported by RobotStudio 5. But if your robot model (i.e. the manipulator itself) is supported by IRC5, then you can create a IRC5 system for that robot and simulate from RobotStudio 5. Since RAPID is the same for S4C and IRC5 you can take the robot program and run in RobotStudio.
Note: Configuration parameters are NOT compatible, i.e. you cannot re-use e.g. MOC.CFG, and EIO.CFG etc. You need to re-define your parameters using the configuration editor of RSO.
ABB0 -
OK!
Thank's a lot Henrik!
