Import of geometries. Errors.
Hello.
I have problems with the import of geometries. The files are kind STEP or ACIS.
RS is not able to import files larger than 40MB. Cry
Until that limits the volume of file RS is capable of importing without giving bug?.
Thank you very much.
Jesus.Smile
  • Hi Jesus.
    I have imported satfiles of 500 mb. It takes time to import but it works.
    After import i save them as lib. Delete them and import the lib and it works very well
    BR Klaus
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
  • Hi,
    The function "Enable Healing" can cause some geometries to grow unexpectedly. Try to uncheck it and import the geometry again. The function is enabled/disabled by the checkbox in the "Import Geometry" dialog, see below.
    ABB
