Import of geometries. Errors.
jesus
Hello.
I have problems with the import of geometries. The files are kind STEP or ACIS.
RS is not able to import files larger than 40MB.
Until that limits the volume of file RS is capable of importing without giving bug?.
Thank you very much.
Jesus.
Hi Jesus.I have imported satfiles of 500 mb. It takes time to import but it works.After import i save them as lib. Delete them and import the lib and it works very wellBR KlausBest Regards
Klaus Soenderhegn
www.cadalysator.dk0 -
Hi,The function "Enable Healing" can cause some geometries to grow unexpectedly. Try to uncheck it and import the geometry again. The function is enabled/disabled by the checkbox in the "Import Geometry" dialog, see below.
ABB0
- 5.4K RobotStudio
- 382 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 247 ScreenMaker
- 2.7K Robot Controller
- 281 IRC5
- 47 OmniCore
- 3 RobotStudio AR Viewer
- 739 RAPID Programming
- 16 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
