RS 5.11.01
I have loaded 5.11.01, earlier I was having 5.11 with machining, & arc welding PP, but now I am not able to reload Machining Power pack,
rajrishiraj
That sounds strange, I have upgrade from 5.11 to 5.11.01 also, and the PowerPacs work fine.Please make sure you have a station opened before you try to load Machining PowerPac.If the problem remains, I recommend you uninstall Machining PowerPac and install again.0
Its done,Thanks a LotRArajrishiraj0
This discussion has been closed.
