RS 5.11.01
I have loaded 5.11.01, earlier I was having 5.11 with machining, & arc welding PP, but now I am not able to reload Machining Power pack,
rajrishiraj
That sounds strange, I have upgrade from 5.11 to 5.11.01 also, and the PowerPacs work fine.Please make sure you have a station opened before you try to load Machining PowerPac.If the problem remains, I recommend you uninstall Machining PowerPac and install again.0
Its done,Thanks a LotRArajrishiraj0
This discussion has been closed.
- 5.4K RobotStudio
- 382 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 247 ScreenMaker
- 2.7K Robot Controller
- 281 IRC5
- 47 OmniCore
- 3 RobotStudio AR Viewer
- 739 RAPID Programming
- 16 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
