Two versions of RobotStudio in one system.
I wonder if there is a possibility to have two different vesions of RobotStudio on the same machine? I need to have RS 5.10 and 5.11 on the same machine for testing purposes.
If anyone had done it before please let me know how to make it works.
Thanks,
regards,
jawojtek2009-03-26 08:49:34
Wojciech Wlodarski
PLABB
  • Hi,
    Yes that is possible, do like this:
    First install RS 5.11.02 (if you have 5.10 installed it will automatically be uninstalled).
    When RS 5.11.02 is installed you can install RS 5.10. Now will 5.10 and 5.11.02 be installed parallel in two different folders (..RobotStudio  and  ..RobotStudio 5.11).
    ABB Robotics
