Two versions of RobotStudio in one system.
I wonder if there is a possibility to have two different vesions of RobotStudio on the same machine? I need to have RS 5.10 and 5.11 on the same machine for testing purposes.
If anyone had done it before please let me know how to make it works.
Thanks,
regards,
jawojtek2009-03-26 08:49:34 Wojciech Wlodarski
PLABB
PLABB
Hi,Yes that is possible, do like this:First install RS 5.11.02 (if you have 5.10 installed it will automatically be uninstalled).When RS 5.11.02 is installed you can install RS 5.10. Now will 5.10 and 5.11.02 be installed parallel in two different folders (..RobotStudio and ..RobotStudio 5.11).Best regards,
ABB Robotics0
- 5.4K RobotStudio
- 382 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 247 ScreenMaker
- 2.7K Robot Controller
- 281 IRC5
- 48 OmniCore
- 3 RobotStudio AR Viewer
- 740 RAPID Programming
- 16 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
