Geometry issues in RS5.12
AlexK
I have a problem with RS5.12 regarding geomatries. Whenever I import a SAT gemoetry I get three checkboxes with Surface Model, Enable Healing and Link to Geometry. I check the first and the last and I am able to select different surfaces and induidual parts that the assably is made of. Everything is great so far.
However whenever I save a station and then reopen it, I do not have the possibility of selecting induvidual parts and I do not have the ability to select surfaces. All these possibilities are gone and theres a red "X" over the symbols in the "Layout" menu. Is there something I'm doing wrong or is this a bug?
Best regards
Alexander K
AlexK2009-04-29 08:44:45 Best regards
Alexander Källberg
Alexander Källberg
Hi Alexander,
Make sure "Load geometry" is checked in the Open Station file dialog.
regards,
Johannes
Johannes Weiman
Software Engineer
ABB Robotics0 -
Hi Johannes,Thank you very much for your help, have never seen that check box, needed someone to point it out for meBest regards
Alexander Källberg0
- 20 Tutorials
- 303 PowerPacs
- 2.8K Robot Controller
- 353 IRC5
- 74 OmniCore
- 849 RAPID Programming
- 24 AppStudio
