Geometry issues in RS5.12
AlexK
I have a problem with RS5.12 regarding geomatries. Whenever I import a SAT gemoetry I get three checkboxes with Surface Model, Enable Healing and Link to Geometry. I check the first and the last and I am able to select different surfaces and induidual parts that the assably is made of. Everything is great so far.
However whenever I save a station and then reopen it, I do not have the possibility of selecting induvidual parts and I do not have the ability to select surfaces. All these possibilities are gone and theres a red "X" over the symbols in the "Layout" menu. Is there something I'm doing wrong or is this a bug?
Best regards
Alexander K
AlexK2009-04-29 08:44:45 Best regards
Alexander Källberg
Alexander Källberg
Hi Alexander,
Make sure "Load geometry" is checked in the Open Station file dialog.
regards,
Johannes
Johannes Weiman
Hi Johannes,Thank you very much for your help, have never seen that check box, needed someone to point it out for meBest regards
Alexander Källberg0
- 5.4K RobotStudio
- 382 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 247 ScreenMaker
- 2.7K Robot Controller
- 281 IRC5
- 48 OmniCore
- 3 RobotStudio AR Viewer
- 739 RAPID Programming
- 16 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
