RS31 does not start !!
I am using ThinkPad T40p with 1GB of RAM.  Everyday, I have to start RS and close at least three times before RS  is running properly.  I reinstalled RS, but the problem reamins.  Is anybody know the cause?  Also, I encountered the RS is not running when using Track.
CPU; 1.6GHz  RAM; 1GB  OS; Windows XP SP1
Mitz
  • Hello Mitz,
    How do you mean start and close? Does RobotStudio crash? How does the errormessage look?
    Best regards
    /Ulrika Mor?n
  • Hi,
    I mean RS freeze at least a few times, before it is running properly. No error message in the RS, because it crshes.
    Mitz
  • Hello again Mitz,
    I see you are a member of the pickmaster forum, have you got a lot of ABB softwares installed?
    Just to make sure; it's when you are starting RobotStudio, not when starting the virtual controller that you get the problem?
    Best regards
    /Ulrika Mor?n
