RS31 does not start !!
I am using ThinkPad T40p with 1GB of RAM. Everyday, I have to start RS and close at least three times before RS is running properly. I reinstalled RS, but the problem reamins. Is anybody know the cause? Also, I encountered the RS is not running when using Track.
CPU; 1.6GHz RAM; 1GB OS; Windows XP SP1
Mitz
Hello Mitz,
How do you mean start and close? Does RobotStudio crash? How does the errormessage look?
Best regards
/Ulrika Mor?n
I mean RS freeze at least a few times, before it is running properly. No error message in the RS, because it crshes.
Mitz
Hello again Mitz,
I see you are a member of the pickmaster forum, have you got a lot of ABB softwares installed?
Just to make sure; it's when you are starting RobotStudio, not when starting the virtual controller that you get the problem?
Best regards
/Ulrika Mor?n
- 5.4K RobotStudio
- 384 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 736 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
