RS 5.12 - Processing Time
ruiguima
I installed the RobotStudio 5.12 an I noticed that is a lot slower in the general operations like apply changes in the rapid compiler...
I as working with the 5.11 version with no problems and a lot faster than the 5.12 version.
Should I reinstall the RS 5.12 version, or did anybody else noticed the same?
Thank you.
BR
http://forums.robotstudio.com/forum_posts.asp?TID=2563
Johannes Weiman2009-05-25 17:40:05Johannes Weiman
Software Engineer
ABB Robotics0 -
Thank You.Everything OK now!0
- 304 PowerPacs
- 2.8K Robot Controller
- 354 IRC5
- 74 OmniCore
- 850 RAPID Programming
- 26 AppStudio
