RS 5.12 - Processing Time
ruiguima
I installed the RobotStudio 5.12 an I noticed that is a lot slower in the general operations like apply changes in the rapid compiler...
I as working with the 5.11 version with no problems and a lot faster than the 5.12 version.
Should I reinstall the RS 5.12 version, or did anybody else noticed the same?
Thank you.
BR
http://forums.robotstudio.com/forum_posts.asp?TID=2563
Johannes Weiman2009-05-25 17:40:05Johannes Weiman
Thank You.Everything OK now!
- 5.4K RobotStudio
- 381 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 247 ScreenMaker
- 2.7K Robot Controller
- 281 IRC5
- 47 OmniCore
- 3 RobotStudio AR Viewer
- 739 RAPID Programming
- 16 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
