extracting curves on the imported geometry
candy
i import a geometry which is formed by two intersecting cylinders.and then i want to extract the intersecting lines.but i do not how.who can help me?thank you!
Hi,Try the feature "Border around Bodies", see below:Henrik Berlin
ABB0 -
Thanks! I would like to ask that your graphics is drawn in the robotstudio, or imported?I import the geometry ,but i can not separate the two cylindricals.
I created it in RS. But it should not matter. But. to use the feature you need to have the geometry in two separate bodies.Henrik Berlin
ABB0 -
yeah,i know,i will have a try.thank you!0
- 399 UpFeed
- 20 Tutorials
- 14 RobotApps
- 301 PowerPacs
- 406 RobotStudio S4
- 2.8K Robot Controller
- 339 IRC5
- 67 OmniCore
- 832 RAPID Programming
- 14 AppStudio
- 107 Collaborative Robots
