extracting curves on the imported geometry
candy
i import a geometry which is formed by two intersecting cylinders.and then i want to extract the intersecting lines.but i do not how.who can help me?thank you!
Hi,Try the feature "Border around Bodies", see below:
Thanks! I would like to ask that your graphics is drawn in the robotstudio, or imported?I import the geometry ,but i can not separate the two cylindricals.
I created it in RS. But it should not matter. But. to use the feature you need to have the geometry in two separate bodies.Henrik Berlin
yeah,i know,i will have a try.thank you!0
- 5.4K RobotStudio
- 382 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 247 ScreenMaker
- 2.7K Robot Controller
- 281 IRC5
- 47 OmniCore
- 3 RobotStudio AR Viewer
- 739 RAPID Programming
- 16 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
