API "Modify Position" event
Hi!
I select a MoveLJ instruction in a path, right-click on it and select "Modify position".
Does it exist an event triggered by the action? I have not found any in the documentation.
Thank you!
Sergej Saibel
  • Hi Sergej,
    The static event ProjectObjectChanged will be raised with ChangeType = Transform.
    Note that the event is actually sent two times, one for the RsRobTarget and one for the RsTarget.
    example:
    [code]
            ProjectObject.ProjectObjectChanged += new ProjectObjectChangedEventHandler(ProjectObject_ProjectObjectChanged);
            void ProjectObject_ProjectObjectChanged(object sender, ProjectObjectChangedEventArgs e)
                if (e.ChangeType == ProjectObjectChangeType.Transform)
                    if (e.ChangedObject is RsTarget)
    [/code]
    regards,
    Johannes
    Johannes Weiman
    Software Engineer
    ABB Robotics
  • Hi Johannes!
    Thank you very much, I will try it. Do you have some documents about all of the events in RS?
    The current API documentation is not so complete.
    Sergej Saibel
