API "Modify Position" event
Hi!
I select a MoveLJ instruction in a path, right-click on it and select "Modify position".
Does it exist an event triggered by the action? I have not found any in the documentation.
Thank you!
Sergej Saibel
Sergej Saibel
Hi Sergej,
The static event ProjectObjectChanged will be raised with ChangeType = Transform.
Note that the event is actually sent two times, one for the RsRobTarget and one for the RsTarget.
example:
[code]
ProjectObject.ProjectObjectChanged += new ProjectObjectChangedEventHandler(ProjectObject_ProjectObjectChanged);
void ProjectObject_ProjectObjectChanged(object sender, ProjectObjectChangedEventArgs e)
if (e.ChangeType == ProjectObjectChangeType.Transform)
if (e.ChangedObject is RsTarget)
[/code]
regards,
Johannes
Johannes Weiman
Hi Johannes!Thank you very much, I will try it. Do you have some documents about all of the events in RS?The current API documentation is not so complete.Best regards,
Sergej Saibel0
- 5.4K RobotStudio
- 382 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 247 ScreenMaker
- 2.7K Robot Controller
- 281 IRC5
- 47 OmniCore
- 3 RobotStudio AR Viewer
- 739 RAPID Programming
- 16 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
