ues the visual system to control robot motion?
hello everyone, i want to ues the visual system to control the robot motion ,but i dont know how to integrate the visual system into the robot controller,my problems are described as follows:
1.the camera is fixed at the terminal of the robot ,the camara is connected to my PC,through the camara ,in my PC i can obtain the position and attitude of the object ,then how can i send the position and attitude to the robotcontrller to make the robot arrive at the position?(attention: the object is moving ,so i need to constantly obtain the object's position and posture, and use them to control the robot movement).
2a__which kind of software should I use? robot studio or Developer Tools(pc sdk or flexpendant )?
3a__Is there any examples ?do you have any easy-of-use idea to solve the problem?
Thank you!
Hi.I have used socket connection to communicate between Vision software and both VC and real robot. That works very fine.Setup your GUI as socket and your robot as socket client... See rapid instruction for socketBest Regards
Klaus Soenderhegn
www.cadalysator.dk0
- 399 UpFeed
- 20 Tutorials
- 14 RobotApps
- 301 PowerPacs
- 406 RobotStudio S4
- 2.8K Robot Controller
- 344 IRC5
- 70 OmniCore
- 842 RAPID Programming
- 19 AppStudio
- 107 Collaborative Robots
