3 external axes setting
Hello.
Some other guys already had a same problem as me. So I looked through documentations TSG_RS36 and 42, and read all topics in here. But I failed to make it work.
Do you have an experience of 3 external axes gantry type station?
My situation is that IRB hangs upside down on a gantry, and the gantry moves X, Y, and Z direction which syncronized each other.
My question is that:
1. First Motor_ axis7( Let say MU20 ) setting was fine. Working well.  (M7C2B1_L1_N8_20.cfg used)
2. For second motor_axis8, I added  "M8C2B2_L1_N5_20.cfg"  selecting EXT.Axis tap.
 ---> system crashed itself. Is it right way whenever I add a external axis, just insert a correct *.cfg file?  In other words,
3 cfg files are needed for 3 MU20 Motors?
I assume that I had something wrong of
1. IRB option miss selected.
2. using wrong "*.cfg" file.
Please tell me the knowhow how you are usally setting 2nd and 3rd external axes.
yours truly,
Jeong-Keen Hwang
Application Engineer
ABB Ltd.
ATMA
KR
Phone: +82 41 529 2343
Fax: +82 41 529 2350
Mobile: 011 9810 7013
email: jeong-keen.hwang@kr.abb.com
JK Hwang38644,452662037
  • As you can see from the image, 2 axes are used separately. If I use 3 same or different motors,  I think axis 1,2,3 can be jogged like IRB. Is there any special CFG file? How do you set up like this case?  if I make this by using "config Edit", it looks OK but doesn't work in TPU.
    JK Hwang38644,5737731481
  • 3ex_axes.zip
    3axes.zip
    Dear All
    Please try  the station and use your own controller IRB1400M2000.
    I failed to make correct CFG file. MU20 for axis7 & 8 and MU30 for axis 9.  If you solve the problem, please send me correct cfg file and particular robot option if you have.
    I appreciate it.
    yours truly,
    Jeong-Keen Hwang
    ABB Ltd.
    ATMA
    KR
  • I solved it by myself. But it's not working in IRC5. How to do it?
  • Hello Guys,
    Normally, these kind of issues are set up using a so called AW setup disk, where all external axes, like gantries and positioners are defined. Please refer to the supplier of this equipment for the files.
    If you have a real robot, you can use the AW disk for the VC as well.
    :) Regards,
    Jan-Jaap
