3 external axes setting
Hello.
Some other guys already had a same problem as me. So I looked through documentations TSG_RS36 and 42, and read all topics in here. But I failed to make it work.
Do you have an experience of 3 external axes gantry type station?
My situation is that IRB hangs upside down on a gantry, and the gantry moves X, Y, and Z direction which syncronized each other.
My question is that:
1. First Motor_ axis7( Let say MU20 ) setting was fine. Working well. (M7C2B1_L1_N8_20.cfg used)
2. For second motor_axis8, I added "M8C2B2_L1_N5_20.cfg" selecting EXT.Axis tap.
---> system crashed itself. Is it right way whenever I add a external axis, just insert a correct *.cfg file? In other words,
3 cfg files are needed for 3 MU20 Motors?
I assume that I had something wrong of
1. IRB option miss selected.
2. using wrong "*.cfg" file.
Please tell me the knowhow how you are usally setting 2nd and 3rd external axes.
yours truly,
Jeong-Keen Hwang
Application Engineer
ABB Ltd.
ATMA
KR
Phone: +82 41 529 2343
Fax: +82 41 529 2350
Mobile: 011 9810 7013
email: jeong-keen.hwang@kr.abb.com
As you can see from the image, 2 axes are used separately. If I use 3 same or different motors, I think axis 1,2,3 can be jogged like IRB. Is there any special CFG file? How do you set up like this case? if I make this by using "config Edit", it looks OK but doesn't work in TPU.
Dear All
Please try the station and use your own controller IRB1400M2000.
I failed to make correct CFG file. MU20 for axis7 & 8 and MU30 for axis 9. If you solve the problem, please send me correct cfg file and particular robot option if you have.
I appreciate it.
yours truly,
Jeong-Keen Hwang
ABB Ltd.
ATMA
KRPhone: +82 41 529 2343
email: jeong-keen.hwang@kr.abb.com0 -
I solved it by myself. But it's not working in IRC5. How to do it?0
Hello Guys,
Normally, these kind of issues are set up using a so called AW setup disk, where all external axes, like gantries and positioners are defined. Please refer to the supplier of this equipment for the files.
If you have a real robot, you can use the AW disk for the VC as well.Regards,
Jan-Jaap0
- 5.4K RobotStudio
- 384 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 734 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
