Profinet connection [MOVED]
Ercan
Hi everybody.
I have 2 problems. And I hope you can have 2 answers for me.
1- I have 3 ABB IRC5 robots. and these robots has profinet fieldbus adapter slave. PLC will be master. My friend made a configuration for these robots. Then I just changed Input/ouput bytes. then they work. But just one robot cant connect to profinet line. Everythng is same in I/O CFG file. Do you have any solitions for me?
2- I want to connect all robots with ethernet switch. All robots connect to ethernet swtich with profinet fieldbus adapter. Is that possible?
Thanks for all
Post edited by Jonathan Karlsson on
