Pauese button 5.61.02
Bob_G
The pause button is not available in simulation in 5.61.02
Is this a bug.
Is this a bug.
Seems to be working OK... Are you playing program from the Simulation play button or via text editor / Flexpendant?0
I have the same issue on my computer with 5.61.02. RS 6.0 appears to have fixed it though. Using the Simulation Play button. It works if the station was created in a previous version, but not if it was created in 5.61.02.0
I found a solution to this problem: http://forums.robotstudio.com/discussion/7796/record-to-viewer-function-not-active
On the Virtual Time option page, uncheck the automatically change virtual time mode and select Time Slice.
- 38 AppStudio
