pick and place
sairam
can u briefly explain how to create pick and place station i.e how to create targets after creating i/o signals and how to simulate the objects pic by robot automatically
can u help me out
can u help me out
https://forums.robotstudio.com/discussion/5153/smart-components-idiots-guide#latest
I think it help you
you should use the picking power pack it makes it easy to simulate this type of application
thank u it helped me ........thanks a lot0
can anyone help me it is picking only one object but it is not placing.......thanks in advance0 -
try to use detach in smart component0
Use detach smart component and NOT logic gate if your using the same signal as attach.0
ya got it thank u0
- 858 RAPID Programming
