3DConnexion mouse in RS 6.03
tckool
I just got a 3DConnexion spacenavigator from a colleague. I installed all the drivers and the mouse is working great in many applications. Unfortunately, in RobotStudio I can only zoom in an out with the mouse, although all the other options are activated.
I tried to edit commands in the "customize commands" window, or from the options window but I couldn't find anything related.
Anyone here knows how to activate all the other options to move around freely in the simulation?
Thanks
Thomas
Thanks
Thomas
Hmm. Mine just worked after I installed it. didn't have to activate anything.0
What version of RobotStudio are you working with if I may ask you?
hmm I think I have 5.15, 5.60, 6.0, 6.01, 6.02 and 6.030
I'll try installing an older version of RS. Keep you posted
I have installed different versions of RobotStudio, without success. My colleague is dealing with the same issues as I described above. I guess we just have to stick to the ordinary mouse and keyboard0
Are you using the latest drivers from 3Dconnexion?
It should "just work". Which OS and driver version are you using? Have you tested it with other apps?Johannes Weiman
Software Engineer
I have downloaded the latest drivers from the website here: http://www.3dconnexion.eu/service/drivers.html. I'm running windows 10 (my colleague windows 7). I also tested it with other apps and there the functionalities do work. From next week on I'm back at the office, I can give more detailed information about drivers etc. then. Thanks for your efforts.
I've just open the box of mine and install it. It's working fine on RS 6.04.01.... I don't know if there is a way to change how the mouse move the 3d models on RS....
Un saludo, kind regards,
Daniel Aguilar
Automation Engineering
Don't want to open additional discussion, so...
RobotStudio 2020.2 (64-bit)Version 20.2.9116.0
3D Connxion SpaceMouse
Mouse works good, but I am wondering how to switch betwwen controlling 1-3 axis and 4-6 axis while using that mouse - same as on flexpendand. On default I can control only 1-3 axis. If I try to switch it be virtual flexpendand it does not take effect.0 -
Found an answer to the problem, if anyone needs that as well: instruction in attachemnt - thanks to PolyRobotics company.0
Solution for me in image below.
I had the exact same problem with my brand new 3dconnexion spacemouse today with RS2021.2 and latest drivers etc. Spacemouse would only zoom in/out but was working fine in the 3dconnexion demo viewer.
After "reset all settings" it started to work.
David
Swedish freelance ABB robot programmer0
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
