RS6.03 freezes creating a system
I would like to test the External Axis Wizard, and I started following the Henrik Belrin tutorial from youtube.
https://www.youtube.com/watch?v=s1Vk-xUDGy4
When I try to create a system from the current offline desing, the RS freezes. I tried with the 32 and 64 bit versions. Even with different Robotwares: 6.03.02, 6.02.01,...
It's freezing all the time in this step, (sorry for the spanish version of the software).
Looks like the RS is not able to create a system from the current offline design even though there is no a track in the design. I've just tried it dropping an IRB6400 in the Station.
Could anybody help over here?
Thanks
/Daniel
https://www.youtube.com/watch?v=s1Vk-xUDGy4When I try to create a system from the current offline desing, the RS freezes. I tried with the 32 and 64 bit versions. Even with different Robotwares: 6.03.02, 6.02.01,...
Thanks
/Daniel
Un saludo, kind regards,
Daniel Aguilar
Automation Engineering
Hello
Are you selecting any options in the previous steps?
Have you tried to reinstall studio?
/Pavel0 -
Same case with me. Tried creating system from layout and it freezes.0
Hello
Please try it with RS6.04 and report if it still fails.
/Pavel0 -
Finally I formatted the whole Pc.... now is working, but this is quite annoying. Is the 3rd time in 1 year that I formatted the PC because RS stucks somewhere, and even reinstalling RS, cleaning register and whatever you could do, still happens the same...Pavel Riabichev said:Hello
/Pavel
I'm actually working with RS6.04
Daniel Aguilar
