Help with External Axes Setup
I am also having problems trying to add an external axis. I tried 3 different robots, 4400, 6400R, and 6600, and created a virtual controller with one external axis. I imported the robot, and the controller started just fine. I then imported the track - T6002_7_7.rlb. Next, I selected Controller Setup, Ext. Axis, and added the parameter file T6001_7_7.cfg. The controller crashed during the warm start with the message "Abbs4vc.exe has generated errors and will be closed by Windows. ...". I have been trying various combinations for the last 3 days, including removing and re-installing RS and RobInstall, but still the same results.
What am I doing wrong?
Jim Haglund0 -
You can download "TSG_RS 36 How to set up a track - external axes" or "TSG_RS 42 How do I coordinate the motion of a track mounted robot with two positioners" from SolutionsBank or software subscription portal?
Thomas AnderssonThomas Andersson
Support Engineer
ABB Automation Technologies
ATMA/RO/AIS0 -
Please someone here help me on how to create our own external axis using kinematic modeler. I already create the external axis using kinematic modeler. The problem is, where can i get the cfg file? Because the cfg file in the robot studio is for the ABB standard external axis only.
ABB Malaysia0 -
Hi zainudin,<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Please send an e-mail to the software support address where you explain what it is that you want to do.
Please also include a .zip file with your station and external axis.
Thomas Andersson
Support Engineer
ATMA/RO/AIS0 -
[QUOTE=Thomas]
[/QUOTE]
Can you please give me the software support address? Thanks.
ABB Malaysia0 -
Please give me your e-mail address so I can send the address to you.
Thomas Andersson
Support Engineer
ATMA/RO/AIS0 -
[QUOTE=Thomas]
[/QUOTE]
This is my e-mail address : zainudin_jusoh@yahoo.com
ABB Malaysia0
- 5.4K RobotStudio
- 384 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 736 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
