API "Modify Position" event
Saibel
Hi!
I select a MoveLJ instruction in a path, right-click on it and select "Modify position".
Does it exist an event triggered by the action? I have not found any in the documentation.
Thank you!
Sergej Saibel
Sergej Saibel
Hi Sergej,
The static event ProjectObjectChanged will be raised with ChangeType = Transform.
Note that the event is actually sent two times, one for the RsRobTarget and one for the RsTarget.
example:
[code]
ProjectObject.ProjectObjectChanged += new ProjectObjectChangedEventHandler(ProjectObject_ProjectObjectChanged);
void ProjectObject_ProjectObjectChanged(object sender, ProjectObjectChangedEventArgs e)
if (e.ChangeType == ProjectObjectChangeType.Transform)
if (e.ChangedObject is RsTarget)
[/code]
regards,
Johannes
Johannes Weiman
Hi Johannes!Thank you very much, I will try it. Do you have some documents about all of the events in RS?The current API documentation is not so complete.Best regards,
Sergej Saibel0
- 303 PowerPacs
- 353 IRC5
- 849 RAPID Programming
- 24 AppStudio
