Robot Studio and VMWare Workstation
I have a computer running under Linux and I'd like to run Robot Studio under Windows XP SP2 with a virtual machine via the VM Ware Workstation software.
So I download the latest version of RS. Then I install it on my virtual machine (VM).
Then when I load RS, I have the following message : "Your Premium version has expired. You could use the functions basis".
But I just can create a system. Not even moving a robot or creating a path or points.
So I thought it was possible at least to try RS during 30 days.
So what's up ???
Thanks for your help
neospirit
So what's up ???
neospirit
The trial period is disabled when running on a virtual machine. You need to activate RobotStudio for it to run.
Why is that ?
The reason is to prevent misuse of the trial period.Henrik Berlin
What if I have a true licenc, can I install RS on a virtual machine ?
neospirit
neospirit2009-10-23 16:04:100 -
Yes, you can. Only the trial period is disabled.Henrik Berlin
ABB0
- 5.4K RobotStudio
- 382 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 247 ScreenMaker
- 2.7K Robot Controller
- 281 IRC5
- 47 OmniCore
- 3 RobotStudio AR Viewer
- 739 RAPID Programming
- 16 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
