Encoding Rapid Files
Jastrab,<?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
You can?_Tt decode rapid modules that have been encoded. You have to make backup copy of the original source.
Also BullsEye software is proprietary, disclosure or modification to the code is strictly prohibited. If you have any problem with BullsEye, please contact your local ABB representative.
Att.
I'm need only paste one instruction in this modul (set bitXZ).Result this is file.doc.In this file is time and date of check tcp.You understand me? I'm speak and write very bad.
Please send to me as well.nwjustforfun@gmail.com0
Hello Marcel,do you have this program also for the other way? not for coding for decoding??0
Hello GranaleNo, the other way round is not possible. Otherwise you could read the secrets of the swedish modules.
How do i load an encrypted module into a system?Is there some special way of doing this?I tried to load an encrypted module into a system in robotstudio using the load module command on the virtual flexpendant.. This resulted in a systemfailure.0
The best way is to order the tool "CD Key Maker" from ABB Robotics. This PC-tool will include an encoder function. See the Additional options manual (3HAC023668-001).0
[QUOTE=Mippaloo]How do i load an encrypted module into a system?Is there some special way of doing this?I tried to load an encrypted module into a system in robotstudio using the load module command on the virtual flexpendant.. This resulted in a systemfailure.[/QUOTE]I was able to load an encrypted file with no issues. There are only two things that I know of that would prevent it from loading. One, the syntax is incorrect. And two, make sure that the instructions, functions and data types are supported by the options available on that robot. I would try loading the unencrypted version first so you can see what part of the module causes errors.0
Please send it to me as well. nwjustforfun@gmail.com0
Please sent this to me as well nwjustforfun@gmail.com0
Please send to me as well nwjustforfun@gmail.com0
Hi!
Could you please send to me also?
vholiveira@gmail.com
Thanks!
I have a software to encode the modules. Send to me a private mensage
with your email adress and I give to you a software!Your faithfully !
_______________________________
Calling cards Switch
online games0 -
need the software too..
could you please send it to me as well
bloodsport55@yahoo.co.in
Thanks..
Do not fear to be eccentric in opinion, for every opinion now accepted was once eccentric..0 -
i need the software too..
Bodo@kebekus.de
Thanks..
Thank you Marcel for the software
Can you send me one as well? Thanks
joe@devtronixs.com
I would also like
You can send to me?
Tks
asdmendonca@gmail.com
I have been using encode for many years without any problems. But now I got a new computer with Windows 7 I got a problem. When trying to execute encode i get the following message:<?: prefix = v ns = "urn:schemas-microsoft-com:vml" />
Anyone seen this? Is there a solution? Contacted ABB and they replied that they will no longer support the 12 year old software encode!0 -
May I get the Rapid file encoding program?fabio.bergamin@gmail.comThanksFabio
C.I.A. Automation and Robotics
www.ciaautomazione.it0 -
Opsss... my email in fabio.bergamin@ciaautomazione.it (NOT fabio.bergamin@gmail.com)Fabio
need it too.. eugene.automates@gmail.com .. thanks
Gently,
could some one send me too?
here mail email: davide.rossi@sdrossi.it
Bye Davide Rossi0 -
[QUOTE]
[/QUOTE]
ABB Spain, doesn't sell this tool, they say that are a internal tool. Any one bought it on other county?.
[QUOTE=Marcel]HiHere is the software to encode. It is 10 years old but still works.
Hint: Don't change the recommended directory: C:encode to put these files in.
Hint: There is no way back (decoding). So keep the original program code.Best regardsMarcel[/QUOTE]
Thanks for share the file with us.
/BlueIcaro
Jorge Turiel0 -
Is there any update to this utility software that works in Win 7?
- 361 IRC5
- 79 OmniCore
- 853 RAPID Programming
- 30 AppStudio
