Initializing error...
Hello
mistary situation...when I restore backup file from real IRC5 controller to VIRC5, this real backup file is working well on real controller.
But after restore the backup file into VIRC5, VIRC5 shows below error and it doesn't boot... what's happening?? Is any parameter adjusting needed for VIRC5??....if there is, please show me the way thank you.
spaik
one more thing, DSQC-328A and DSQC-378A were installed.Best & Kind Regards,
spaik0 -
Hi Spaik,
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Please send an e-mail to the software support address.
If you haven't got the software support address then please give me your e-mail address so I can send the address to you.
We will need to know which Virtual IRC5, RobotStudio Online and RobotWare version you have.
Please also include a .zip file with the backup that cause the problem.
Thomas Andersson
Support Engineer
ABB Automation Technologies
ATMA/RO/AIS0 -
This error is certainly provoked by the configuration of one IO card during the download of the "EIO.cfg file". Delete this file in first time, to see if the error disappears. I had the same problem and I modified the following line: -Name "interbus" -UnitType "d351A" -Bus "DeviceNet1" -DN_Address 10 to... -Name "interbus" -UnitType "Virtual" -Bus "Virtual1" and now it's Ok !
- 5.4K RobotStudio
- 384 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 736 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
