Authentication Type [WebWare Server]
Hello-
I am trying to set the Authentication Type in WebWare 4.6 to be Windows instead of SQL Server type. When I enter the AD account I get a connection failed error, when I enter SA it works fine. Does anyone have tips or advice on how to get this to work as I really need to quit using the SA account.
THANKS
HiCan you please attach a screen dump on the error.Thanks!Lennart H0
The user has access to the DB as sysadmin and I tried with with DOMAINusername and that did not work either...0
Any help....0
Please read the attached instruction. It's about creating a user in SQL-server who can log in via WebWare server using Windows authentication. Perhaps it can help you...webwiz/151/WindowsAuth_SQLSever_WebWare.zip
Lennart H0
