Positioner joint value problem
hi guys,
I got a problem with positioner joint value make me so sad. I would like to make rotary table keep rotating continuously and it did work well when joint value less than 1000. after the joint value exceed a certain value, 1150 approximately, it stopped. Anyone can help me? Thanks in advance.
actually, I found the joint limit of this positioner is from -1145 to 1145. But anyone can tell me is it possible to modify the limit and how?
U can change it from Config->Motion->Arm->Upper joint bound/Lower joint bound.
But if 1145 is maximum allowed value of that joint u cant set limit above of that value.
BR.
Erdem Karaçeper0 -
Thanks a lot!
That did work but no matter how much I set the upper and lower joint bound, the limit of the joint would change into -11459~11459... what's the problem here?
- 5.4K RobotStudio
- 382 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 247 ScreenMaker
- 2.7K Robot Controller
- 281 IRC5
- 48 OmniCore
- 3 RobotStudio AR Viewer
- 739 RAPID Programming
- 16 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
