IO simulator
Is there anything like the IO simulator in RS 3.x available in RS 5.0? Very helpful in testing RAPID cell control applications.
Jan-Jaap
Hi Jan-Jaap
In the next release of RS there will be a new IO simulator with a lot of improvments compared to the one in RS 3.2, but for now you have use RobotStudio Online to simulate your IO's.
Per Svensson
Company Specialist
Hi Per,
How do I force an input or output? In RSonline, I get the message: "the operation failed due to safety reason!".
Regards,
Jan-Jaap0 -
Hi Jan-Jaap,
If you change the Access Level for the I/O-signal to ALL, it will be possible to force it in RSO. You will find this setting in RSO under: Configuration - I/O - Signal.
Is there anything in the released verision similar to the event table - connect the IO to the parts in the simulation? I have been able to set up the IO through Robot Studio Online.
Thank you.
Kavel
Hello Kave,
No, it is not possible to use event tables in this version.
But in the next release will we have event tables and a I/O-simulator.
ABB Robotics0
- 5.4K RobotStudio
- 384 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 734 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
