Reltool
Mikethk
Im new... My Rutine::
PROC
Opg5_90()
Set Do9Lampe1;
MoveJ offs (p000, -50, 50, 30), v1000, z50, tool1;
MoveL reltool (p000, -50, 50, 0), v1000, fine, tool1;
MoveL reltool (p000, -175, 120, 0), v1000, fine, tool1;
MoveL reltool (p000, -50, 190, 0), v1000, fine, tool1;
MoveJ offs (p000, -50, 50, 30), v1000, fine, tool1;
Reset Do9Lampe1;
I used offs instead of reltool before. When reltool is used it changes the points in the Z direction..... Only offs to reltool is done.... Is it right that reltool need to do this? I didnt even place any
z:=90
z:=90
Im cunfused....
reltool operates in the tool coordinate system.So although you have 0 z it will still probably move in z in the world coordinate system as they are usually not aligned. Offs works in whatever workobject the position is in.0
- 367 IRC5
- 858 RAPID Programming
