RS5.07 Locks up my Laptop
skphelps
I have recently installed RS 5.07 and every time I attempt to import a robot library or start a system my computer locks up just as it seems RS is trying to import the robot model.
Any suggestions??
I am running and IBM T43p laptop:
- 2.00GHz Pentium Processor
- 1.00GB RAM
- 15GB Free space on the HD
- ATI Mobility FireGL V3200 Video Card with 128MB Ram
- Video Card is set to 1280x1024 and 96dpi
- Running Windows XP SP2
Any help would be great.
Kind Regards!
Kind Regards,
Steve Phelps
Steve Phelps
Hi Steve,
We would suggest that you configure your ATI Adapter with the following settings:
Open the ATI Adapter properties dialog which can be found under:
Start Menu/Settings/Control Panel/Display/Settings/Advanced.
Select the ATI Configuration tab. Add a new Configuration Profile with the following options enabled:
- Force copy swap
- Wait for vertical retrace
- Enable OpenGL acceleration
Also make sure that you have version 8.163.1.1 of that particular driver.
Kind Regards
FredrikFredrik Syr?n
Program Manager
ABB Automation Technologies0 -
This information also helped me. I was also locking up.
I have an IBM T42p with an ATI Mobility Fire GL T2
I have the same problem.
You have to download a patch from windows. It can switch between two different way of using your graphic card accelerator.
ABB software support can help you
Ask for this document "RS5.07.1688.Direct3D_Patch(A1.0).pdf"
and this patch "RS5.07.1688.Direct3D_Patch(A1.0).zip"
Frendly regards
Henri
Henri van de Kolk
Robot Engeneer
AWL-Techniek
Harderwijk, Netherlands0 -
Hy, I had the same problem, but changing my display settings didn't help. I'm using T43p with 2G RAM and FireGL v3200 with 256MB RAM.
Problem solved by changing rendering in RS -> Tools -> Options -> Graphics -> Performance
Hope this helps somebody else to.
thank you Bill0
- 398 UpFeed
- 13 RobotApps
- 299 PowerPacs
- 405 RobotStudio S4
- 327 IRC5
- 65 OmniCore
- 820 RAPID Programming
- 8 AppStudio
- 3 RobotStudio AR Viewer
- 105 Collaborative Robots
