How İ communicate C# and Robot Studio Virtual Controller
Hello everybody<br>my problem is that i didnt comminicate c# and robotstudio. <br> I write a interface for robot (real) but i need making some changes using robot studio. Now i will what i do step by step<br>1) open robot studio and add new robot with virtual controller <br>2) syncronize virtual controller and robot<br>3) then i read fallowing link <br><a href="http://developercenter.robotstudio.com/Index.aspx?DevCenter=RobotCommunication&OpenDocument&Url=../RobotCommunicationAppManual/doc26.html">http://developercenter.robotstudio.com/Index.aspx?DevCenter=RobotCommunication&OpenDocument&Url=../RobotCommunicationAppManual/doc26.html</a> <br>this.scanner = new NetworkScanner<br>this.scanner.Scan();<br>ControllerInfoCollection controllers = scanner.Controllers;<br>foreach (ControllerInfo controllerInfo in controllers)<br> {<br>item = new ListViewItem(controllerInfo.IPAddress.ToString());<br>item.SubItems.Add(controllerInfo.Id);<br>item.SubItems.Add(controllerInfo.Availability.ToString());<br>item.SubItems.Add(controllerInfo.IsVirtual.ToString());<br>item.SubItems.Add(controllerInfo.SystemName);<br>item.SubItems.Add(controllerInfo.Version.ToString());<br>item.SubItems.Add(controllerInfo.ControllerName);<br>this.listView1.Items.Add(item);<br>item.Tag = controllerInfo;<br>}<br>But c# didnt connect robot studio. i don't see any robot in listview ? i make mistake but in where? please help me
Post edited by John Wiberg on
1
Hello, maybe you forget to add the option pc interface to your virtual robot.
Did you create a new system using your robot backup? And then create a new cell using this new system, only then you have an exact copy of your real robot with same options.
BR
Peter
thankss peter i solved the problem thanks a lot:)0
- 364 IRC5
- 83 OmniCore
