How Can I read robot TCP speed?
You could try it with the following EIO.CFG
Best regards
Marcel
EIO:CFG_1.0:5:0::
EIO_BUS:-Name "Virtual1" -ConnectorID "SIM1"
-Name "Profibus_FA1" -BusType "PBUS" -ConnectorID "FA1"\
-ConnectorLabel "Profibus-DP Fieldbus Adapter"
EIO_UNIT_TYPE:-Name "Virtual" -VendorName "ABB" -ProductName "Virtual unit"
-Name "DP_SLAVE_FA" -BusType "PBUS" -VendorName "ABB Robotics"\
-ProductName "Profibus-DP Fieldbus Adapter Slave" -InternalSlave \
-PB_ProductId 6161 -PB_InputSize 50 -PB_OutputSize 50
EIO_UNIT:-Name "ProfiBus" -UnitType "DP_SLAVE_FA" -Bus "Profibus_FA1"\
-PB_Address 10-Name "UnitSim" -UnitType "Virtual" -Bus "Virtual1" -TrustLevel 0
EIO_SIGNAL:-Name "aoSurfSpeedTCP" -SignalType "AO" -Unit "ProfiBus"\
-SignalLabel "Surface Speed Robot in mm/min" -UnitMap "192-207"\
-Access "All" -MaxLog 0.54612 -MaxPhys 0.54612 -MaxBitVal 32767#
EIO_ACCESS:-Name "ALL" -Rapid -LocalManual -LocalAuto -RemoteManual -RemoteAuto
SYSSIG_OUT:-Status "TCPSpeed" -Signal "aoSurfSpeedTCP" -Arg1 "ROB_1"
1 -
Thanks Marcel ı will try that. Can I read current tcp speed?thanks again0
With that configuration it will be sending the TCP speed out all the time because it's defined using a System Output which is always updating even if your robot program is stopped!
�0 -
Ercan said:Thanks Marcel ı will try that. Can I read current tcp speed?thanks again0
- 358 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 29 AppStudio
