Delete / Remove System
When you want to remove a network system from the controller list you right-click and choose "delete."
I don't understand the use of the word "delete" when you want to remove the system from the network controller list.
I know it's petty, but deleting a system seems so ominous, when all you're doing is disconnecting from the controller.
5
A colleauge that is not in the core team asked the same question last week. Will the Controller dissapear or what? Add Controller - Remove .....0
File > Online and choose the network controller. Under the Controller tab, the left Controller window shows the network controller under the Network heading.
The only way I know of disconnecting from the network controller is to right-click and choose delete. Then it's removed from the list.
Thanks for bringing this to our attention. We will change it it one of our upcoming releases.
/Henrik
(Internal ref: WI11749)
Hello,I have a question, at least regarding the same area of RobotStudio:I accidently closed the left Controller window under the Controller Tab, where the connected systems appears, and now I can´t find a way to get it back.0
Try Default Layout, or manually select the Windows you want back, see picture,
ABB0
- 5.4K RobotStudio
- 383 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 733 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
