IRC5 : maximum number of retries
If I have reached the maximum number of retries in an error handler, the system is stopped.
Can it then simply be restarted by the start button on the Flexpendant?
  • Yes, after an error reset, if you push the start button it will start over with the retries, you could also change the allowed number of retries.
  • Micky
    Micky ✭✭✭
    there is a new instruction "ResetRetryCount" inside RAPID which can be used to reset the retry counter, so that you can use a more intellegant error handler.
    Please refer to the RAPID reference Manual.
    /BR
    Micky
  • I'm going to guess your running robot-ware 9? or any version under 11? i recently had the issue you stated, and i corrected that annoyance by updating from 5.09 to 5.15.
  • Dedex
    Dedex
    edited March 2021
    How we can do this?Change the allowed number of retries.
  • You can also have a look at NoOfRetry in Configuration - Controller - General Rapid - NoOfRetry. Read up on it in Manual
