How to break out of WHILE ?
pollux
You break out of while when the conditions on top are not met0
Hi pavpav,Thanks I thought so but will hoping RAPID supported a C-ish `break`. But if that's not possible I'll add it to the while condition.p.0
The closest I can think of is the RETURN statement that will exit the current routine. That might work if you put your WHILE statement in a dedicated routine.
Hey Pollux,You can also use the GOTO statement like this:MODULE WhileLoopVAR num count := 0;PROC TestWhileloop()WHILE TRUE DOIF count > 5 THENGOTO nextPart;ENDIFIncr count;ENDWHILEnextPart:TPWrite "Out of while loop";Stop;ENDPROCENDMODULEhope it helps,LarsLars Glud
Danrob A/S0 -
Ah thanks guys for all the possible solutions!0
But then this would do the same with less code and without the use of GOTO which I ware thought never to use when I started programming ABB robots.
MODULE WhileLoopVAR num count := 0;PROC TestWhileloop()WHILE count <= 5 DOIncr count;ENDWHILETPWrite "Out of while loop";Stop;ENDPROCENDMODULEBest regards
Alexander Källberg0
- 5.4K RobotStudio
- 385 UpFeed
- 15 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 285 IRC5
- 47 OmniCore
- 3 RobotStudio AR Viewer
- 748 RAPID Programming
- 15 Wizard Easy Programming
- 3 Job listings
