A way in RAPID code to identify Robot/Controller model and whether its online or offline?
Is there a way in RAPID code to identify Robot/Controller model and whether its online or offline?
Just need a function that looks inside somewhere in the controller and return a value that represents the robot model (IRBxxxx) and/or is the code running on an actual controller or on a virtual controller.
Any ideas are welcomed!
  • Hello,
    to check if robot is virtual/real:
    IF RobOS() THEN
          Execution statements in RC
    ELSE
         Execution statements in VC
    ENDIF
    and for robot model
    VAR string rtype;
    rtype := GetSysInfo(\RobotType);
    more info in when you look up the getsysinfo command in the manual.
     Br
     Peter
