ClawGripper doesn't attach objects
Liberona
Hi everyone,
I have problems with the ClawGripper included in RobotStudio. Just I want to attach/dettach objects, in order to simulate a palletizing process.
I checked that ClawGripper is not detectable by sensors, but I have doubts in how to activate giOpenClaw and giOpenFixer
It is controlled by 2 group output from the virtual controller... but the problem is I can't attach/detach objects in the claw... I could activate de sensor, but I don't know how to assign the bag in order to be attached to the gripper and move the bags.
Please any advice you can give me will be appreciated
Pablo Liberona
Pablo Liberona
Hi Pablo,
The ClawGripper is made to work with the Palletizing PowerPac,so I don´t know how that one is made. But here can you download a zip-file with some tutorials about how to create Smart Components, as for example a tool that can attach/detach objects:
https://abb-my.sharepoint.com/personal/anders_spaak_se_abb_com/Documents/Shared with Everyone/Smart Component tutorials.zip?web=1
Regards,
AndersBest regards,
Thanks Anders, I've used ClawGripper with Paletizing PowerPac 6.02 and works perfectly... without the PowerPac is pretty complex to be integrated to a robot.
Regards,
Pablo0 -
Ok, lets try Dropbox:
https://dl.dropboxusercontent.com/u/5195001/Smart Component tutorials.zip
Regards,
AndersBest regards,
ABB Robotics0
- 5.4K RobotStudio
- 383 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 733 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
