Robot mounting
jeffdu
We have bought a used IRB 6650-125/3.2 M2000. Can't find it in the product specification. Do you have to mount it on a plate? Can you mount it directly on concrete floor?
Thank you in advance
Jeff
Jeff
As long as the floor is flat to the required tolerance (0.3 mm for IRB6650) (or you grout under the robot) and the floor is capable of withstanding the loads (as detailed in the manual) then you can mount directly to the floor.1
graemepaulin said:As long as the floor is flat to the required tolerance (0.3 mm for IRB6650) (or you grout under the robot) and the floor is capable of withstanding the loads (as detailed in the manual) then you can mount directly to the floor.0
- 360 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
